SoCal Sprinters
Driving style and Hello.
Goto page 1, 2  Next
Pax Rolfe
PostPosted: Sat Feb 11, 2012 2:35 pm    Post subject: Driving style and Hello. Reply with quote
Hello everyone, I am new to Karts but not new to solo. I had the opportunity to run Wendell Karr-ake's kart at a local event back in August and I'm ruined. I have contracted the Karting disease. I hope to have my own next month and run a bunch of events this season.
As a benchmark, my first time in the kart, I was a little over 2 seconds slower than Wendell on a 40-50 second course. My question is, what adjustments do i need to make to my driving style? Are there common mistakes that new karters make when transitioning from door-slammers?
I've seen a lot of posts on setup and things mechanical, but not a lot on the nut behind the wheel. Can I get some tips, things to focus on initially that might shallow my learning curve a bit.
Thanks in advance.
Pax
Tulsa, OK
Joe Ricard
PostPosted: Sat Feb 11, 2012 5:29 pm    Post subject: Reply with quote
subscribing to this as well
My .02 cents is if you aren't shaking like a leaf while getting back to your grid spot you didn't go fast enough.
Arrow AX-8/ Rotax Sr.
Pax Rolfe
PostPosted: Sat Feb 11, 2012 5:41 pm    Post subject: Reply with quote
Got that one covered Smile
Pax
Tulsa, OK
Tim Walsh
PostPosted: Sat Feb 11, 2012 7:09 pm    Post subject: Reply with quote
I haven't been karting long, but there are a couple things to think about.
1. Don't forget you don't have a diff or a suspension, therefore throw everything you know about car setup out the window. Seriously, most of it will just mess you up.
2. Because you don't have a diff, a kart will scrub speed badly anytime the wheel is turned.
2a. When you're off the gas, you will understeer, so make sure you can exit every corner on the gas.
3. When launching or moving around the grid, keep the wheel completely straight until you've let the clutch out all the way. I stalled the kart a few times in grid because I had the wheel turned. The kart doesn't make enough torque at 4-6k to get the kart moving when they're turned.
2002 Birel CR32V/ StockMoto w/PI
Jason Vehige
PostPosted: Sun Feb 12, 2012 10:10 am    Post subject: Reply with quote
If you trail brake a lot in cars start breaking the habit.... be aware of old tires... it can get very frustrating to chase tires that have simply gone off... they normally loose grip long before the rubber is gone....
otherwise the only real advice I can give is to LOOK AHEAD as much as possible!!! and HAVE FUN!!! Cool
Jason Vehige
05 Vanspeed Sirio / SGM sl204
Pax Rolfe
PostPosted: Sun Feb 12, 2012 10:22 am    Post subject: Reply with quote
Jason Vehige wrote:
If you trail brake a lot in cars start breaking the habit....otherwise the only real advice I can give is to LOOK AHEAD as much as possible!!! and HAVE FUN!!! Cool
Thanks! That's the kind of stuff I'm looking for. I do left-foot-brake and trail brake a lot. Having thought about it A BUNCH, I think my biggest gains are going to come from corner entry. I think that's where I'm weak. I could probably carry more speed through the corner also, once I get more than 8 runs under my belt.
Pax
Tulsa, OK
Trey Davis
PostPosted: Sun Feb 12, 2012 12:36 pm    Post subject: Reply with quote
I can attest to the trail braking deal. I got myself into plenty of squirreliness trying that. Braking early and in a straight line is very important.
Two huge things I learned last year: Slow down the hands and roll on the gas. I came out of some lower horsepower cars and got used to stomping the gas.
05CRG/99Honda
Joe Ricard
PostPosted: Sun Feb 12, 2012 3:58 pm    Post subject: Reply with quote
Find a sprint track to do tons of laps on . However your chassis tuning will be significantly different.
the driving aspect will certainly make you better dodging cones.
Robbie Nelson
PostPosted: Mon Feb 13, 2012 5:42 am    Post subject: Reply with quote
Joe Ricard wrote:
Find a sprint track to do tons of laps on.
Agreed! Practice time at a sprint track is well worth it to a novice.
When you get your own kart, don't spend too much time tuning it. IMHO, the nut behind the wheel needs about year of running before you start to mess with the chassis. Get the carb jetting to where it's "safe" and just run it.
Tom Reynolds
PostPosted: Mon Feb 13, 2012 7:19 am    Post subject: Reply with quote
This is true, even for not the novice, tons of time on the sprint track can be huge. A great way to do this is never do more than 3 laps in a row, let your tires cool completely and then go out again. This will get you used to what a parking lot will feel a lot better than endless laps on warm tires though that's good for shifting practice.
Unfortunately I could not disagree more with this. I believed this myself and now realize it was simply years I lost that I could have tuned the kart to be faster, easier to drive and very educational. I got lucky my first nationals in the kart, my setup out of the box was great for Lincoln, but last year I spent the entire week chasing the setup and never was completely happy.
Jared Langenfeld
PostPosted: Mon Feb 13, 2012 1:31 pm    Post subject: Reply with quote
Last season was my first season in a kart (after 5+ years in cars), and I would say the following was the biggest things I had to learn:
1. You REALLY have to look ahead and get used to the perspective of a kart. When you are walking a course, squat down every once in a while to really see what you are going to see.
2. You have to be smoother with your inputs. Jabbing the brakes will unsettle the kart and being jerky with the wheel will unsettle the kart.
3. Brake in a STRAIGHT line! I learned quickly that if I tried to trail brake, I would spin. It is very tempting to trail brake when you are always left-foot braking, but don't do it!
4. You REALLY do have that much grip! I remember the first few events when I started to get close to Shawn in times and was amazed at how much grip I had.
5. LOOK AHEAD!
6. HAVE FUN!
After a season in Shawn's kart, I am hooked and bought my own kart at the end of last year and I'm excited for this season to start!
2008 Mike Wilson with Honda CR125 shifter
Pax Rolfe
PostPosted: Mon Feb 13, 2012 5:44 pm    Post subject: Reply with quote
Thanks guys, keep'em coming. Turns out next month came sooner than later. Going to fetch my kart the weekend after next. First event is mid march. It's a kart that's already being used for solo and consistently places in the top third in PAX. Hopefully it will continue to do so with Pax behind the wheel Smile
Pax
Tulsa, OK
Jim McMahon
PostPosted: Tue Feb 14, 2012 3:49 pm    Post subject: Reply with quote
Joe Ricard
PostPosted: Wed Feb 15, 2012 6:29 am    Post subject: Reply with quote
Yep, or my favorite one I tell my wife when she drives her kart. Gas is on the right, it goes to the floor.
Bill Schmidt
PostPosted: Thu Feb 16, 2012 10:56 pm    Post subject: Reply with quote
Pax,
I co-drove with Wendell the 2nd day of Nats last year, after my shifter cable broke on my butterfly shifter mechanism. His kart is wicked fast!
Bill Schmidt
'88 Red Devil F500 4-link rear (Rotax)
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.075204999999999 (40.36%), total time:0.186322, queries:38
