KartSport North America - LB
Ribtect - SS (non-flash)
KG Plastics - FB
Vega Red air pressure
Rick Brockman
PostPosted: Tue Jul 24, 2001 7:26 pm    Post subject: Vega Red air pressure Reply with quote
Would anyone mind sharing their experience with the Vega Red tires being used by the Rotax Max series?
I'm quite familier with the Bridgestone YGC and usually begin with pressures about 8.5 psi up front and 10.5-11 in the rear.
At what pressures do the Vega's seem to be optimum at?
Do they seem to like more or less heat than the YGC?
Are they faster for qualifing being scrubbed a few laps, or being stickers?
Any information on these tires would be appreciated.
Thanks.
Matt Cleaver
PostPosted: Tue Jul 24, 2001 7:44 pm    Post subject: Vega Red air pressure Reply with quote
If I remember correctly, it seems the reds need more pressure than the YGCs. Somwhere like 14-18 psi. Can anyone confirm this, we only ran these tires for a short time.
Pete Van Ginkel
PostPosted: Tue Jul 24, 2001 8:00 pm    Post subject: Vega Red air pressure Reply with quote
I run them at 10-12lbs.
Pete
Rick Brockman
PostPosted: Tue Jul 24, 2001 8:01 pm    Post subject: Vega Red air pressure Reply with quote
quote:
Pete
Would that be hot or cold?
Pete Van Ginkel
PostPosted: Tue Jul 24, 2001 8:05 pm    Post subject: Vega Red air pressure Reply with quote
cold
John Desouza
PostPosted: Wed Jul 25, 2001 6:33 am    Post subject: Vega Red air pressure Reply with quote
Depending on the weather and track temp I have had success with 12-14 #'s cold. They have tremendous grip when new. I have found that they tend to consistently go away after a few laps each session.
Nick Weil
PostPosted: Wed Jul 25, 2001 1:46 pm    Post subject: Vega Red air pressure Reply with quote
Rick,
We have run the Vegas at seven events now in Florida since February. Earlier in the year we started with 14lbs. cold, but as the year has progressed and the heat comes up i have started using 12lbs. cold as my baseline. Depending on the track temp that my be a little high even still. I remember last week in Jacksonvilee I think I may have gone as low as 10.5 - 11.0 cold at one point. I hope this helps...
Nick
Rob Schumske
PostPosted: Wed Jul 25, 2001 5:59 pm    Post subject: Vega Red air pressure Reply with quote
I run the vega reds and we start out with 12-13 psi. cold. They get to about 15psi when hot. We use regular air also as appose to nitrogen. Try out different tire pressures and see what works best. I think the manufaturer states 16-18 psi????? Dont ask me why though. good luck
Pete Van Ginkel
PostPosted: Wed Jul 25, 2001 9:40 pm    Post subject: Vega Red air pressure Reply with quote
quote:
I`m just going off memory, but I think there site says 10lbs.
Pete
Pete Van Ginkel
PostPosted: Wed Jul 25, 2001 10:29 pm    Post subject: Vega Red air pressure Reply with quote
quote:
Try lowering the pressure a little.
Gary Kozuma1
PostPosted: Thu Jul 26, 2001 3:13 pm    Post subject: Vega Red air pressure Reply with quote
Folks,
The HS recommended pressure is 9 PSI. Check out www.sscracing.com/vega/index.htm In my experience I ran my rears pretty low at about 10-11 hot in the rear and about 2 psi higher in the front. But that's the HS, is the "red" the HS? I'm not sure.
Also, if your rear tires have a couple of "humps" when you look at them, they are very happy.
I wish we could get back to 6" tires!
Gary K.
Rob Linders
PostPosted: Fri Jul 27, 2001 9:52 am    Post subject: Vega Red air pressure Reply with quote
[QUOTE]Originally posted by Gary K.:
[QB]Folks,
Hi Gary,
What does this mean? I try and get an even grain accross my tires...am I doing something wrong?
Rob
Terry Grau
PostPosted: Sun Jul 29, 2001 2:53 pm    Post subject: Vega Red air pressure Reply with quote
The Vega web site lists 12 psi as the recommended pressure for the XR Red's.
I assume that is hot and find them loose at higher pressures.
Terry
DB time: 0.643445 (78.76%), total time:0.816956, queries:40
