Italian Motors - LB
Ribtect - SS (non-flash)
DRT Racing - FB
Problems with Honda RPM's
Goto page Previous  1, 2
Kerry Neilson
PostPosted: Thu Jun 20, 2002 12:50 pm    Post subject: Problems with Honda RPM's Reply with quote
Most of the responses are accurate and possible.If the govenor and cam have been stripped,tach is hooked up proper( at idle speed should read 12-1400)stiffer valve springs( g200 or old gx140 part#)Intake centre at around 111 (plus or minus 1 deg), the engine should hit 68-7000 on a good day air wise. The e-tubes that are coming in the 200`s have been inconsistent, you want a 5x5 stock tube with a.076 centre hole. The tubes that were faves with the 160`s(3x3)run too rich.
Brad Onuch
PostPosted: Fri Jun 21, 2002 1:25 am    Post subject: Problems with Honda RPM's Reply with quote
kerry, what is the correct part number of the e tube?
Hance Lord
PostPosted: Tue Jun 25, 2002 5:51 am    Post subject: Problems with Honda RPM's Reply with quote
Kerry:
Any hints about where that e-tube comes from? I'm looking for one but have no part number, and local is not a big fan of guessing them!
Page 2 of 2
DB time: 0.125707 (41.64%), total time:0.301879, queries:37
