Italian Motors - LB
FUEL PUMP AROUND SYSTEM VS REG CARB
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Jimmy McNeil
PostPosted: Sat Jan 21, 2012 10:56 am    Post subject: Reply with quote
Come to the dark side Steve
http://www.shopswedetech.com/Speed_Concepts_GFS_p/gfs.htm
Ken Schilling
PostPosted: Sat Jan 21, 2012 1:53 pm    Post subject: Reply with quote
Jimmy McNeil wrote:
And while im on my rant, the new system is about 10% of the upkeep as the pump around. I use to take apart the pumps to clean them before every race. With the new system the pumps pulse inlet is facing down, any oil that gets into the system drains down out of the pumps.
This year, I pulled the lines off the pumps about 3 times all year to let the oil run out.
^+1!!!
I also used to run a pump around and cleaned them of oil buildup each day. This was a pain...
The GFS system with the pulse inlet facing down, uses gravity for oil collection. This allows me to very quickly remove the pulse line from each pump, quickly shoot a squirt of carb clean up each pulse line to drain the oil and reattach. I use clear pulse line so I can easily see any oil buildup. No need to zip tie the pulse lines to the pump(s) either, just pull off/push on. This convenience and problem prevention is almost worth the cost alone... Of course the other performance benefits are just as important though!!!
Ken Schilling
SKUSA Data Administrator
Greg Lindahl
PostPosted: Mon Jan 23, 2012 11:17 am    Post subject: Reply with quote
Tap 1/8 NPT threads in the top and bottom of the common pump manifold and drain the oil from the chamber regularly.
The length of the pulse hose determines how quickly and if oil reachs the chamber, if the pump is above the pulse line on the engine.
Harmonics pumps the oil uphill if the hose is not "tuned" the right length.
PostPosted: Mon Jan 23, 2012 12:23 pm    Post subject: Reply with quote
The later style double pumpers have a set screw opposite of the pulse line nipple. All that has to be done is pull off the pulse line, unscrew the set screw, spray some brake in it, put it back together. No more than a 5 minute job....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Greg Lindahl
PostPosted: Mon Jan 23, 2012 4:41 pm    Post subject: Reply with quote
Cool!
Mike Goebel
PostPosted: Mon Jan 23, 2012 4:44 pm    Post subject: Reply with quote
CR
That's gotta include a bathroom break! Wink
Mike G.
Tom Barth
PostPosted: Mon Jan 23, 2012 5:53 pm    Post subject: Reply with quote
Why not use a Dellorto fuel pump and eliminate hoses, tanks and draining? Wink
Tom Barth
http://www.greenflagkarting.com/
Power is good...more power is better... too much power is just right!
PostPosted: Mon Jan 23, 2012 6:01 pm    Post subject: Reply with quote
CR
Mike G.
That included a liter break Wink
Because it doesn't cost $700 Very Happy
CR
Spencer Uzri
PostPosted: Tue Jan 24, 2012 2:50 am    Post subject: Reply with quote
What is the cost comparison for a Keihin PWM/PWK + GFS v. Dellorto carb (which can handle a Mikuni pump)?
PostPosted: Tue Jan 24, 2012 7:47 am    Post subject: Reply with quote
The Dellorto carb is not legal in stock Honda, what's the point of the comparison?
Steve Buckner
PostPosted: Tue Jan 24, 2012 12:15 pm    Post subject: Reply with quote
Thats what I did and It works Great. Cost $48.69
Spencer Uzri
PostPosted: Tue Jan 24, 2012 7:45 pm    Post subject: Reply with quote
Just an observation regarding to the supposed "low-cost" argument for the Keihin.
The Keihin was chosen for stock moto because it was a) part of the OEM '99 CR125 pkg & (supposedly) b) because it cost less than a Dellorto. If the Keihin needs a GFS to operate as smooth as a Dellorto (which works with the Mikuni pump), then what is the cost comparison?
John Denman has said more than once that he favored the Dellorto over the Keihin when the rules were being drawn up, but the die is cast now.
PostPosted: Tue Jan 24, 2012 8:33 pm    Post subject: Reply with quote
The Keihin was chosen for stock moto because it was a) part of the OEM '99 CR125 pkg & (supposedly) b) because it cost less than a Dellorto. If the Keihin needs a GFS to operate as smooth as a Dellorto (which works the cost comparison with the Mikuni pump), then what is the cost comparison?
I think it was chosen because at the time it was by far the most popular carb on the Honda motors, easily available/supported, and nearly everyone knew how to tune it.
CR
CR
Benn Herr
PostPosted: Tue Jan 24, 2012 8:46 pm    Post subject: Reply with quote
Keihin PWM $219.95
Plastic "tee" $0.50
Fuel Line $2.00
Mikuni Round Fuel Pump $32.99
Total $255.44
Keihin PWM $219.95
Fuel Line $2.00
Dellorto Bypass Fuel Pump $48.69
Total $270.65
Keihin PWM $219.95
Small Inlet Seat $24.95
Fuel line $2.00
Total $279.89
Keihin PWM $219.95
Magic Can (used) $25.00
Fuel line $2.00
Total $279.94
Keihin PWM $219.95
Pump-Around Conversion $179.00
Fuel line $4.00
Mikuni Round Fuel Pumps (included in conversion price)
Total $402.95
Keihin PWM $219.95
Swedetec GFS System $399.99
Fuel line $4.00
Total $623.94
Side note: The PWK is $10.00 cheaper.
There is your comparison. Some people spend more money on their kart, it's because they want to. Nobody is making them.
Any of the systems will work if you take care of them. Any of them will let you down if you don't take care of it.
You pays your money and you takes your chances!
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
Jimmy McNeil
PostPosted: Tue Jan 24, 2012 9:00 pm    Post subject: Reply with quote
Ive heard the 38mm Dellorto is around $400.
Page 8 of 10
DB time: 0.173401 (41.84%), total time:0.414445, queries:38
