GARY DELCOURE
Posted: Sat Jan 07, 2012 7:44 am Post subject: FUEL PUMP AROUND SYSTEM VS REG CARB |
| CAN ANYONE TELL ME WHAT SYSTEM IS THE BEST. NORMAL CARB OR RUNNING A PUMP AROUND SYSTEM. WHAT IS THE ADVANTAGE OF THE PUMP AROUND SYSTEM AND IS IT EASY TO TUNE WITH THIS SYSTEM? |
Ed Watts
Joined: 29 Nov 2002 Posts: 358 Location: United States, New Jersey, Jackson
Posted: Sat Jan 07, 2012 9:54 am Post subject: |
And the dead of winter debate continues.
Its just cleaner. Pump around paid for itself in saved fuel. _________________ #8 CRG JWR Maxter
Retired Leary Mod-Honda |
Enzo Iadevaia
Joined: 14 Aug 2006 Posts: 199 Location: United States, New York, Long Island
Posted: Sat Jan 07, 2012 12:45 pm Post subject: |
| Ed Watts wrote: | And the dead of winter debate continues.
however today feels like spring..  |
Steve Eady
Posted: Sat Jan 07, 2012 4:19 pm Post subject: pump around |
Gary
Give me a call on monday after 9am, I give you the ups and downs of the different systems. We are the shop that does most of the pump around conversions for most of the big engine builders, we have done hundreds of them in the last 4 years.
Steve @ Extreme Motorsports (530)949-8975
www.extremegokarts.com |
Tom Barth
Joined: 22 Oct 2001 Posts: 1400 Location: United States, Michigan, Waterford
Posted: Sat Jan 07, 2012 5:32 pm Post subject: |
Some day it will sink in....A pump around is a bandaid to correct a fuel pump problem that can be corrected with a plastic Tee and a piece of fuel line.
But I'm sure no one really cares as long as the PA costs more money and adds more fuel line and fittings.  _________________ Tom Barth
http://www.greenflagkarting.com/
Power is good...more power is better... too much power is just right! |
John Denman
Joined: 19 Jul 2001 Posts: 4846 Location: United States, Texas, McKinney
Posted: Sat Jan 07, 2012 8:03 pm Post subject: |
Pumparound solves 2 problems.
First the pintle valve was designed for gravity feed pressure; pump pressure is significantly higher, enough that it unseats the needle and overfills the bowl. In many cases a simple T-fitting to bleed off pressure is enough to correct it.
The second problem with some carbs is the floats may catch on the bowls with lateral G-forces. Not a problem on a bike. If this happens the float may stick open or closed just long enough to be a problem.
Ideally the Dell'Orto carb would have been selected as it doesn't suffer from either problem. _________________ John Denman
Producer for RTMP
http://www.kartweb.com |
Tom Barth
Posted: Sun Jan 08, 2012 5:23 pm Post subject: |
John,
I have installed a tee and routed pump lines to bypass excess fuel and engine runs fine. I don't see any reason for floats to hang up. But yes, use the Dellorto by all means. _________________ Tom Barth
Michael Korody
Joined: 03 Sep 2011 Posts: 47 Location: United States, California, Rancho Santa Fe
Posted: Sun Jan 08, 2012 5:42 pm Post subject: |
another route is the gravity feed system. Track magic used to make a verson of it and Sweedtech currently still does. I use the gfs on a cr125 and am really impressed with the system, it pulls smooth and never floods the carb during long hard cornering... at 400 bucks its not cheap but is recommended if you can afford it.
http://www.shopswedetech.com/Speed_Concepts_GFS_p/gfs.htm
also if you plan to race check to make sure the system is legal for your class...
Last edited by Michael Korody on Mon Jan 09, 2012 10:03 pm, edited 1 time in total |
Randy Mckee
Posted: Sun Jan 08, 2012 6:40 pm Post subject: |
| Michael Korody wrote: | | the gfs is legal in skusa stock moto, but the pump around is not. |
Pump-around is legal in SKUSA spec honda and I believe it always has been. I've been running it for 5 or 6 years. _________________ Randy
#123 TonyKart - S4 Stock Honda |
Steve Buckner
Posted: Sun Jan 08, 2012 7:31 pm Post subject: |
Last edited by Steve Buckner on Sat Jan 21, 2012 5:30 pm, edited 1 time in total |
Doug Welch
Joined: 18 Jul 2001 Posts: 2402 Location: United States, state of mind, Somewhere
Posted: Sun Jan 08, 2012 8:30 pm Post subject: |
For those of you who have not been in the sport long, high lateral G forces were a problem at one major track. After 4 fast right hand corners the Mikuni carb would be completely out of fuel so that when the driver came out of the left hand hairpin, the motor fell flat on its face. The track was Norman, OK and the race that was held there was the SKUSA PMT final. The pump around completely fixed the problem. Even those engines that "never" had a problem had a problem at Norman.
I have always run the pump around as it makes jetting very consistent for all tracks under all conditions. By the way, you don't need to spend $400 to get the conversion done, Steve can convert your carb for a fraction of that. _________________ Doug |
Oscar Aguilera
Posted: Sun Jan 08, 2012 9:28 pm Post subject: |
we should call it the Okie dry pump syndrome set up....then there wouldnt be a debate about the pump around.
now all tom has to do to keep this going is tell us how he never had a problem at oklahoma when we ran clockwise.
gary plz do a search and you will never find the answer,,,because most all the systems work...it depends on your needs, your budget and mostly who will be helping you jet because that person may prefer one over the other.
if you are new here,,,,welcome! but the question you asked might as well have been on politics or religion....sorry buddy.
key point: if you kart is working...dont mess with whatever system is on it! |
Jimmy McNeil
Joined: 12 Apr 2006 Posts: 1479 Location: United States, California, visalia
Posted: Sun Jan 08, 2012 10:27 pm Post subject: |
| Quote: | | I herd the Holley 650 Double Pumper works the best. |
Only if you have it polished and buy the fancy anodized bolts to hold it together. |
Joined: 29 Aug 2002 Posts: 2954 Location: United States, New York, Ossining
Tom Barth
Posted: Mon Jan 09, 2012 5:27 pm Post subject: |
Oscar,
I could run at any track without the PA and have no problems. Wouldn't put up with it. Just need to plumb it correctly.  _________________ Tom Barth
