SKUSA (non-flash) - LB
Streeter - SS
Spec Honda Pipe Cracking Solutions???...
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Larry Andrews
PostPosted: Tue May 31, 2011 10:58 pm    Post subject: Reply with quote
Give the pipe a place to go and it won't have to crack in order to get there. Best part is that the o-ring gland dimensions stay the same...you'll still get good sealing.
<shrug>
Tom Barth
PostPosted: Wed Jun 01, 2011 4:22 pm    Post subject: Reply with quote
Roy,
Iv'e put a 36mm on the ICC for the long track but lately the best set up is with the 30mm. Most guys (tuners) out there don't understand what makes the ICC run like it does. I.E. the ICC turning 14,000 R's is designed to use the 30mm carb. At 13,500+ the engine is getting plenty of fuel/air. Bigger is not always better. 'Just right' is best. Remember the smaller venturi makes for a more responsive throttle. You can put the biggest carb you want on the moto engine, still won't run with a well tuned ICC.
I've also changed the ignition to handle more compression...no help. Just do the things to the ICC that it likes (all within) CIK regs and it is a 'happy camper'.
Tom Barth
http://www.greenflagkarting.com/
Power is good...more power is better... too much power is just right!
Roy Montgomery
PostPosted: Wed Jun 01, 2011 8:12 pm    Post subject: ICCS Reply with quote
Tom Barth wrote:
Roy,
Thanks Tom...I agree... I have both and the ICC's are really on another level for sure.
Sonny Van Hook
PostPosted: Wed Jun 15, 2011 2:10 pm    Post subject: Reply with quote
Larry:
Great post. Thanks for trying to stay on topic.
Sonny
Kosmic T9/CR80
FREE Stock Moto Build and Rebuild Guides
Slip-fit crankshaft bearings for Stock Moto engines (CLICK)
Steve Eady
PostPosted: Thu Jun 16, 2011 6:21 am    Post subject: Reply with quote
Larry
Yes great way to explain it, thats what we do on our personal engines and have never had a problem.
Steve @ Extreme Motorsports
www.extremegokarts.com
"on-line store"
Mike Goebel
PostPosted: Thu Jun 16, 2011 8:39 am    Post subject: Reply with quote
From mfg Tech Centre welding department
I hope this is allowed other wise I have to fork out another $350. Total BS!!
Mike G.
Doug Hayashi
Location: United States, California, H.B. - Center of the Universe
PostPosted: Thu Jun 16, 2011 10:46 am    Post subject: Reply with quote
Mike G.
Send it to RLV, they'll fix it for about 40% of the cost of a new pipe.
-Doug
Mike Goebel
PostPosted: Thu Jun 16, 2011 11:09 am    Post subject: Reply with quote
Yeah I had them fix 2 so far for about $125 ea time. I'm trying to find a fix that lasts Laughing .
Mike G.
Sam Zavaglia
PostPosted: Thu Jun 16, 2011 3:48 pm    Post subject: Reply with quote
Mike,
Take a bore scope with you so tech can see there is nothing funny happening underneath the repair.
Should tech still not allow that then they are just a bunch of aholes. Everybody knows that the pipe can crack there and that is the only logical reason for your repair.
www.samzavaglia.com
Mike Goebel
PostPosted: Thu Jun 16, 2011 4:04 pm    Post subject: Reply with quote
Sam Zavaglia wrote:
Mike,
Yeah but then tech guy will see the kanuter valve is under there!
Mike G.
Bernard Muminovic
PostPosted: Fri Jun 17, 2011 5:23 am    Post subject: Reply with quote
Tom Barth wrote:
Jeff, you get what you pay for.
I do not buy the over priced high maintenance knock on the ICC! Comparing the ICC to the moto has to be done with a level playing field.
I hear the moto chant....that it is cheaper and runs forever. Take a look at the posts in shifter karts and tech talk. most are moto problems.
A well set up KZ will run with zero problems and out perform the moto.
Racing is going to cost money. Let's not dilute real racing with five & dime substitutes.
+1
www.KartingConnect.com
www.neShifterKartSeries.com
www.facebook.com/neshifterkartseries
PostPosted: Fri Jun 17, 2011 6:26 am    Post subject: Reply with quote
+1
I'll take a cracked pipe over a an ICC crank rebuild every time!!!
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Tom Barth
PostPosted: Fri Jun 17, 2011 4:51 pm    Post subject: Reply with quote
Chris wrote:
Yeah I know. I don't see many KZ crank breaks, only timely rebuilds. But it is nothin' compared to the moto scrap yard I see on these posts. Smile
Tom Barth
PostPosted: Fri Jun 17, 2011 4:57 pm    Post subject: Reply with quote
Tom Barth wrote:
Worst case it costs $125 to fix the occasional cracked pipe, I know the parts for a KZ crank refresh is at least twice that!!!
I'll take the occasional cracked pipe, you can keep the KZ cranks!!!
CR
Erik Maxfield
PostPosted: Sun Jun 19, 2011 10:46 am    Post subject: Reply with quote
5 years of road race.
I have not cracked a pipe. My EGT is frequently 1400+ degrees. EGT gauge port located 3.875" from the beginning of the pipe.
I have used home built mounts and the Hegar mounts.
Of course the kart is a garage queen this year though.
Erik
The early bird gets the worm.....
The second mouse gets the cheese....
Stock CR125.
Chassis-FrankenKART
Intrepid/ITAL combination
Page 4 of 7
DB time: 0.275546 (47.43%), total time:0.580991, queries:38
