Paul Hutt
Joined: 26 Sep 2009 Posts: 388 Location: United States, Washington, Olympia
Posted: Thu Apr 28, 2011 6:57 am Post subject: ? on Re-Oiling Simple Green Air Filter |
Using K&N Recharger Kit #99-5000 for WF Simple Green air filter.
1) Is this the correct K&N kit.
2) Approximately how much oil you use in re-oling the air filter. Maybe the approximate time used to spray from the pressurized can.
3) For the Simple Green air filter do you apply the oil from the inside of the filter as stated in the directions for auto application.
Edit/Delete Message _________________ Race Grandpa
Panic Motorsports West |
Joined: 04 Dec 2004 Posts: 1989 Location: United States, Michigan, Williamsburg
Posted: Thu Apr 28, 2011 8:33 am Post subject: |
Do like Jimbo said and use an oiled foam pre-filter. Not much to it really, a little bit of oil goes a long way.
Heartbeat Power, LLC. |
Paul Hutt
Posted: Fri Apr 29, 2011 10:35 am Post subject: |
| John Matthews wrote: | Do like Jimbo said and use an oiled foam pre-filter. Not much to it really, a little bit of oil goes a long way.
Cheers, |
John,
I have never seen these on the WFs. Approximately how much does it cost. _________________ Race Grandpa
Posted: Sat Apr 30, 2011 7:22 am Post subject: |
Hi Paul,
It's basically a foam sleeve that goes over your air cleaner, drop me a PM with your address and I'll send you one. _________________ John Matthews
