Michael Taksa
Joined: 25 Jul 2001 Posts: 1393 Location: United States, Massachusetts, Boston
Posted: Fri Apr 01, 2011 9:00 am Post subject: CGR Road Rebel 2005 Seat Position Chart |
| Anyone got any links to seat mounting charts for 2005 - ish CRG Road Rebel? The seat is medium MoGo. |
Joined: 19 Jul 2002 Posts: 4290 Location: United States, South Jerrrsey,
Posted: Sat Apr 02, 2011 12:27 pm Post subject: |
For a medium just clamp a board to the bottom of the frame rails offset, 1" left of center then front to back and tilt in a comfortable position.
Yamaha KT100 Service Center
40 years karting experience |
Michael Taksa
Posted: Sat Apr 02, 2011 6:50 pm Post subject: |
| OK, bottom lined up with bottom of frame rails, 1 inch to the left of center, tilt based on comfortabe position, still missing one dimension, usually measured from front rail to front of seat, or do I mount first then put the kart on scales and move seat forward or back to achieve 43-57% weight? |
Mike Goebel
Posted: Sat Apr 02, 2011 6:54 pm Post subject: |
| Michael Taksa wrote: | | move seat forward or back to achieve 43-57% weight? |
That's an ideal situation.
mfg Technology Centre
Michael Taksa
Posted: Sat Apr 02, 2011 6:58 pm Post subject: |
| Loooks like I will have a lot of holes:) |
Chris McGinley
Joined: 28 Nov 2008 Posts: 358 Location: United States, New Jersey, Sewell
Posted: Sun Apr 03, 2011 3:52 am Post subject: |
I think this applies to your year also...here are the numbers from the CRG manual.
for 100cc junior
600mm - front of chassis to right side of seat
590mm - front of chassis to left side of seat
215mm - seat top/back edge to axle
for 100cc
610mm - front of chassis to right side of seat
600mm - front of chassis to left side of seat
205mm - seat top/back edge to axle
for 125cc
620mm - front of chassis to right side of seat
610mm - front of chassis to left side of seat
205mm - seat top/back edge to axle _________________ Chris McGinley
Monster Raceworks
Rotax Masters
http://www.njkarting.org
http://www.btbsecurity.com |
Posted: Sun Apr 03, 2011 8:52 am Post subject: |
That's the idea of clamping the board on there, so you don't have to drill holes. If you've got scales just slide it around until you got the numbers and mark it. If it's not comfortable where you marked it then you've got to see where you can put your lead to make up the difference.
Michael Taksa
Posted: Mon Apr 04, 2011 6:10 am Post subject: |
| Thanks everyone. |
