Margay Racing
MG Tires - SS
Edit
Michael Boone
PostPosted: Sat Oct 23, 2010 11:50 am    Post subject: Edit Reply with quote
N/C
Last edited by Michael Boone on Tue Jan 11, 2011 10:11 pm, edited 2 times in total
Les Prins
PostPosted: Mon Oct 25, 2010 11:55 am    Post subject: Reply with quote
Swiss Auto or Biland?
Michael Boone
PostPosted: Mon Oct 25, 2010 8:54 pm    Post subject: Reply with quote
N/C
Brad Linkus
PostPosted: Tue Jan 11, 2011 9:20 am    Post subject: Reply with quote
As the USA importer for Swissauto I have been asked by the factory to respond to these false rumors. Sodikart has not dumped the SA250 and continues to supply engines for their production kart line. Swissauto is not having any problems with the engine bottom end or any other parts of the engine.
Customers who do not follow the specific operational instructions provided by the factory will have problems.
This engine does not have an oil pump. The oil is circulated through the engine from the piston pressure (up and down) through a reed valve in the lower case, it is a dry sump. If the customer does not use the proper weight of oil it will not flow through the oil passages and through the crankshaft which will cause failure of the lower end bearing.
The most common customer mistakes (besides not reading the directions):
Using the incorrect oil weight. 0w30 weight required, no exceptions!
Not warming up the engine to operational temperature before running under load.
Repeated running of the engine to the rev limiter.
Taking advice from someone who thinks they know everything.
If you service the engine at the recommended intervals and follow these simple operational requirements the Swissauto SA250 engine will have no problems and give you many years of enjoyment as one of the most powerful and reliable kart engine available.
Brad Linkus
Engines4racing
http://www.engines4racing.com
engines4racing@msn.com
http://www.coloradokartracing.com
http://www.imimotorsports.com
Dean Graves
PostPosted: Tue Jan 11, 2011 10:01 am    Post subject: Reply with quote
That's what happens when two smokers start running 4 cycles. Happens all the time till they figure it out. Cool
Michael Boone
PostPosted: Tue Jan 11, 2011 11:13 am    Post subject: Reply with quote
N/C
Last edited by Michael Boone on Tue Jan 11, 2011 10:12 pm, edited 2 times in total
Dean Graves
PostPosted: Tue Jan 11, 2011 11:28 am    Post subject: Reply with quote
Michael,
Do you race 4 cycles regularly?
Brad Linkus
PostPosted: Tue Jan 11, 2011 12:08 pm    Post subject: Reply with quote
Direct from Swissauto:
"Sodikart only advertises and stocks the customized SA-250 engines for their OEM kart packages. They are allowed to sell the 34-39hp version to customers in France by special order. There has not been any history of problems from the limited number of 34-39hp engines Sodikart has sold to date."
Dean Graves
PostPosted: Tue Jan 11, 2011 2:38 pm    Post subject: Reply with quote
The SA-250’s are on Sodi's shop(Itaka) web site.
http://www.itaka.fr/gb/engines/sa250-engines,249.html
Brad Linkus
PostPosted: Wed Jan 12, 2011 5:38 pm    Post subject: Reply with quote
Michael
You must have realized you were libeling SwissAuto with those posts and removed them, thank you. You should never had made them in the first place, very irresponsible. Do you really think no one from Swissauto reads the forums on Ekarting?
DB time: 0.117473 (37.79%), total time:0.310818, queries:38
